Branching based on LDAP error messages
Is there a way to capture the error message that has been returned from an LDAP Bind call and perform a branch decision based on the content of this message?
In my access policy I have the LDAP Bind retry count set to a value of zero so that the fallback branch is triggered and I can log the session variables. I see reference to “session.ldap.last.errmsg” however this is never populated with the message that is returned from my ldap server.
Thanks.
Which version you are referring? There was a related issue which fixed in 11.0 which requires retry to be > 1 for the message to set.
I am using version 11.4.1 HF3 After double checking, I had the attempts set to 3. I changed this to 1 and session.ldap.last.errmsg was correctly populated. I clearly was doing something wrong the first time that I tried this. At least it works now.
