Blocking a URL except from specific IP addresses
We would like to block access to a specific URL for a web application except if it is coming in from our VPN (known IP address ranges) or from our internal network. ie /admin but allow /user. How should the irule be written
To clarify:
If a user makes a request for www.domain.com/admin, deny them unless they are on your internal network (we’ll say 10.0.0.1/24).
Correct?
If so, then you’d want something like:
  if { [HTTP::uri] starts_with "/admin" } {
    if {[IP::client_addr] starts_with "10.0.0" } {
      pool http_pool
      reject
This is, of course, an extremely simple example. If you wanted to add a bit more intelligence/flair, you could use a network range when doing the comparison, send a custom HTTP response, etc.
HTH,
Colin
Thanks to all! This has been a great help!
