Block URIs and forward traffic 2 pools on same VIP
Hi Team,
We currently have a requirement for single VIP to service 2 URLs and also to check URI and only allow 4 specific URIs.
I currently have it as 2 different VIPs with 2 pool and have an irule attached to it block URIs as below which is working as expected to allow specific URIs
switch -glob [HTTP::uri]]
“/abc*” -
“/bcd*” -
“/efg*” -
“/cvy” -
default
drop
I have prepared another irule which can be used to pass the traffic specific pool depending on the hostname.
set hostname [string tolower [HTTP::host]]
switch $hostname {
“abc.com” {
pool abc_pool
default {
do nothing use the pool for VIP
Can I combine these irules to achieve which i wanted or would it be easier to use ltm policy?
You can combined two irule in Single iRule but above requirement is not clear.
Just put the dummy Application name and URL ==> Redirect Pool name
example :
URL ==>> www.abc.com and URI==> /pqr or /xyz ==> redirect pool ==> pool_A
URL ==> www.def.com and URI ==> /sat or /hij ==>> redirect pool ==> Pool_B
Hope you understand it.
