Hello,
I’m new to F5/iRules and I have a requirement to block external ip’s from invoking any /dev60cgi/f60cgi URI call that doesn’t include the string ‘DRECSINHIST’ or ‘DRECSFFEDBF’. The iRule should do the following:
1) detect if IP::client_addr is external by reading from a data class ($::approved_clients)
2) if IP::client_addr is internal, then it will LB to the pool associated with the virtual
3) if IP::client_addr is external, then it will check for /dev60cgi/f60cgi in the URI
4) if 3 = true, then the iRule will look for ‘DRECSINHIST’ or ‘DRECSFFEDBF’ in the URI string
5) if URI strings contains ‘DRECSINHIST’ or ‘DRECSFFEDBF’ then LB to the pool associated with the virtual, else display an HTTP response that says “no forms access allowed to external client ip’s”
Here’s what I’ve come up with to address these requirements. Everthing seems to work except the part where the HTTP::respond streams HTML back to the requesting client. The iRule effectively determines if the IP::client_addr is external/internal and blocks invocations to any forms that aren’t in our approved forms list, but it fails to display any type of response…the broswer just hangs indefinitely.
if { not [matchclass [IP::client_addr] equals $::approved_clients] } {
if {[HTTP::uri] contains “/dev60cgi/f60cgi”} {
if { not [matchclass [HTTP::uri] contains $::approved_forms] } {
log local0. “URI requested by [IP::client_addr] blocked”
log local0. “URI requested = [HTTP::uri]”
HTTP::respond 200 content “ErrorError No Access to forms via external address”
Any thoughts?
iRule newbie…
FYI…here’s what the LTM log shows when someone accesses an unauthorized form from an external ip address
Thu Apr 10 16:28:12 CDT 2008 tmm tmm[1661] Rule oracle_formservlet_filter HTTP_REQUEST: URI requested = /dev60cgi/f60cgi?appletmode=nonformsHTMLpageTitle=HTMLpreApplet=code=oracle/apps/fnd/formsClient/FormsLauncher.classwidth=400height=100archive=/OA_JAVA/oracle/apps/fnd/jar/fndforms.jar,/OA_JAVA/oracle/apps/fnd/jar/fndformsi18n.jar,/OA_JAVA/oracle/apps/fnd/jar/fndewt.jar,/OA_JAVA/oracle/apps/fnd/jar/fndswing.jar,/OA_JAVA/oracle/apps/fnd/jar/fndbalishare.jar,/OA_JAVA/oracle/apps/fnd/jar/fndaol.jar,/OA_JAVA/oracle/apps/fnd/jar/fndctx.jar,/OA_JAVA/oracle/apps/fnd/jar/fndlist.jargp14=jinit_appletcachegv14=offjinit_appletcache=offgp2=resp_appgv2=FNDgp3=respgv3=APPLICATION_DEVELOPERgp4=sec_groupgv4=STANDARDgp5=functiongv5=FND_FNDPOMPOgp6=other_paramsgv6=gp7=forms_urlgv7=https3A2F2Fhostname.domainname.com3A4432Fpls2Fnaoatst12Ffnd_icx_launch.runforms3FICX_TICKET3D26resp_app3DFND26resp_key3DAPPLICATION_DEVELOPER26secgrp_key3DSTANDARD26start_func3DFND_FNDPOMPO26other_params3Dencoding=UTF-8gp8=error_urlgv
Thu Apr 10 16:28:12 CDT 2008 tmm tmm[1661] Rule oracle_formservlet_filter HTTP_REQUEST: URI requested by 66.xxx.xxx.xxx blocked
Did you try to switch browsers like say I.E. vs Firefox? Just a simple test to rule out the browser.
I figured it out. I’m using the same logic as before, but now I’m searching for a different string (had to uses wireshark on a non-ssl server to figure this out)
if {[HTTP::uri] contains “/fnd_icx_launch.runforms”} {
HTTP::redirect “http://somewhere.com”
Here’s the key string
GET /pls/dbname/fnd_icx_launch.runforms?ICX_TICKET=&resp_app=CSFCUST&resp_key=DRES_ASO_RESP&secgrp_key=STANDARD&start_func=DRECSFFEDBF&other_params= HTTP/1.1
Accept: */*
Accept-Language: en-us
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; InfoPath.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30)
Host: hostname.domainname.com
Connection: Keep-Alive
Cookie: oracle.uix=0^^GMT-5:00^p; oracle.uix=0^^GMT-5:00^p; BIGipServerdbname_http_pool=2759328266.29215.0000; JServSessionIdroot=gs9z80d911.qRjIa34MsAXIngPAcBbPpx0LaBDJpAiHnwTyqAjNqQjM/AbJphCLbxiKa0--; dbserver_dbname=fFXMJKIYaHBAets8D7_X5Q0h:S
HTTP/1.0 302 Found
Date: Thu, 10 Apr 2008 22:25:45 GMT
Server: Oracle HTTP Server Powered by Apache/1.3.19
Location: http://hostname.domainname.com/dev60cgi/f60cgi?lang=US&env=NLS\_LANG=‘AMERICAN\_AMERICA.UTF8’+FORMS60\_USER\_DATE\_FORMAT=‘DD-MON-RRRR’+FORMS60\_USER\_DATETIME\_FORMAT=‘DD-MON-RRRR%20HH24%3AMI%3ASS’+NLS\_DATE\_LANGUAGE=‘AMERICAN’+NLS\_SORT=‘BINARY’+NLS\_NUMERIC\_CHARACTERS=‘.,’&form\_params=+config=‘dbserver\_dbname’+icx\_ticket=‘.A5yJBWacW3TQ7ScPm3ElNw..’+resp=‘CSFCUST%2FDRES\_ASO\_RESP’+secgrp=‘STANDARD’+start\_func=‘DRECSFFEDBF’&encoding=UTF-8
Content-Type: text/plain
