Hello Devs!
Is it possible to block a specific SOAP method without ASM? Could an iRule do this?
Thanks!
Hello Devs!
Thanks!
You can use an Irule:
if {[string tolower [HTTP::method]] contains "YOUR METHOD"}{
log local0. "Forbidden HTTP method ([HTTP::method]) attempted by [IP::client_addr]"
reject
For example, to reject requests containing the TRACE method, enter the following text:
if {[string tolower [HTTP::method]] contains "trace"}{
reject
In your case you can autorize only wanted method !!!
For more information:
regards
