This iRule performs a reverse DNS lookup on the client IP address and blocks any which don’t match a specific top level domain. This specific example sends an HTTP response. But you could also send a TCP reset using reject.
when CLIENT_ACCEPTED {
# Trigger a name lookup for new connections
set do_lookup 1
log local0. "[IP::client_addr]:[TCP::client_port]: New connection to [IP::local_addr]:[TCP::local_port]"
# Check if we haven't done a lookup already on this connection
if { $do_lookup }{
log local0. "[IP::client_addr]:[TCP::client_port]: Collecting HTTP for new lookup"
# Hold HTTP data until client IP address is resolved
HTTP::collect
# Start a name resolution on the client IP address
NAME::lookup -ptr [IP::client_addr]
when NAME_RESOLVED {
# FQDN of client IP address
set ptr [string tolower [NAME::response]]
log local0. "[IP::client_addr]:[TCP::client_port]: Lookup result: $ptr"
# Check if ptr record ends with .mil
if { $ptr ends_with ".mil" } {
# Release HTTP data for .mil addresses and track that we've done a lookup for this connection
log local0. "[IP::client_addr]:[TCP::client_port]: Valid ptr, releasing HTTP"
set do_lookup 0
HTTP::release
# PTR record does not end with ".mil", reject the connection
log local0. "[IP::client_addr]:[TCP::client_port]: Invalid PTR, blocking HTTP request."
HTTP::respond 403 content "Invalid PTR!\r\n"
TCP::close
The bug ( BZ 340659 ) 404 Page not found | BIG-IP Documentation was resolved in 10.2.2, so I am sharing an updated iRule to do this in 11.x ========================================================================== when RULE_INIT { Set debug to 0 for no logging Set debug to 1 to just log blocks Set debug to 2 to log blocks and valid requests set static::debug 1 Ensure this points to your Data Group set static::domain_blacklist_dg “domain_block_blacklist” Set IP for your DNS Server set static::my_dns 192.168.10.1 Set name of VS if using a local Virtual Server set static::my_dns my_dns_vs } when CLIENT_ACCEPTED { set do_lookup 1 set is_blocked 0 set full_domain “” set base_domain “” if { $static::debug > 1 } { log local0. “Connection Accepted from IP_Addr:[IP::remote_addr]” } } when HTTP_REQUEST { if { $static::debug > 1 } { log local0. “Processing Request from IP_Addr:[IP::remote_addr]” log local0. “Do Lookup: $do_lookup Is Blocked: $is_blocked” log local0. “My_DNS: $static::my_dns” } if { $do_lookup } { grab the client base domain reverse lookup of IP Address set full_domain [RESOLV::lookup @$static::my_dns inet -ptr [IP::remote_addr]] grab the base domain (top level plus subdomain) from full_domain set base_domain [join [lrange [split $full_domain .] end-1 end] .] set do_lookup 0 } if { $is_blocked } { if { $static::debug > 0 } { log local0. “IP_Addr:[IP::remote_addr] Reverse_Lookup:$base_domain blacklisted (Already Blocked)” log local0. “Full Domain: $full_domain” } send a TCP reset reject } else { if { [class match $base_domain contains $static::domain_blacklist_dg] } { if { $static::debug > 0 } { log local0. “IP_Addr:[IP::remote_addr] Reverse_Lookup:$base_domain blacklisted (Blocked)” log local0. “Full Domian: $full_domain” } set is_blocked 1 send a TCP reset reject } else { if { $static::debug > 1 } { log local0. “IP_Addr:[IP::remote_addr] Reverse_Lookup:$base_domain $full_domain Accepted” } } } } ==========================================================================
Thank you, John, this is exactly the snippet I needed to get the lookup to work
For anyone else needing this snippet I’ve formatted it as code
Not certain I’ve inserted all the new lines needed.
when RULE_INIT {
# Set debug to 0 for no logging
# Set debug to 1 to just log blocks
# Set debug to 2 to log blocks and valid requests
set static::debug 1
#Ensure this points to your Data Group
set static::domain_blacklist_dg "domain_block_blacklist"
#Set IP for your DNS Server
#Set name of VS if using a local Virtual Server
#set static::my_dns my_dns_vs
set do_lookup 1
set is_blocked 0
set full_domain ""
set base_domain ""
if { $static::debug > 1 } { log local0. "Connection Accepted from IP_Addr:[IP::remote_addr]" }
log local0. "Processing Request from IP_Addr:[IP::remote_addr]"
log local0. "Do Lookup: $do_lookup Is Blocked: $is_blocked"
log local0. "My_DNS: $static::my_dns"
if { $do_lookup } {
# grab the client base domain reverse lookup of IP Address
#grab the base domain (top level plus subdomain) from full_domain
set do_lookup 0
log local0. "IP_Addr:[IP::remote_addr] Reverse_Lookup:$base_domain blacklisted (Already Blocked)"
log local0. "Full Domain: $full_domain" } send a TCP reset reject
log local0. "IP_Addr:[IP::remote_addr] Reverse_Lookup:$base_domain blacklisted (Blocked)"
log local0. "Full Domian: $full_domain"
set is_blocked 1
#send a TCP reset
reject
log local0. "IP_Addr:[IP::remote_addr] Reverse_Lookup:$base_domain $full_domain Accepted"
