Block request by IP and send an HTTP response
Just getting into iRules and I want to block a specific IP from being able to access a webpage but return an HTTP response back to the browser. I am attempting to do this, but still not quite getting it right. Can anyone offer a suggestion that would help?
when RULE_INIT {
  set static::IPBlock "ServerServer Error`-999999 `
                API traffic is currently blocked. Please contact your System Administrator for assistance. BLOCKBLOCK 0
                DISTRIBUTION MESSSAGE "
when CLIENT_ACCEPTED {
    if  { [IP::addr [IP::client_addr] equals 172.18.33.226] } {
    set clientIP [IP::client_addr]
    if {$clientIP eq 172.18.33.226}
    HTTP::respond 200 content "${static::IPBlock}"
The CLIENT_ACCEPTED event is not required. [IP::client_addr] is available in the HTTP_REQUEST event. There is a bracket missing after the ‘if’ in the HTTP_REQUEST event. You should use the IP::addr command to compare IP addresses
    if {[IP::addr [IP::client_addr] equals 172.18.33.226]} {
Your use of a static variable to hold the response is ok, but I would consider using an iFile, which makes it easier to manage.
