when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals xx.xx.xx.xx/xx] } { reject } } it seems it doesn’t work for existing connection
any workaround?
any workaround?
CLIENT_ACCEPTED is triggered when connection is established. if connection is already established, it won’t work.
another method is to keep collecting/releasing payload (e.g. TCP::collect/TCP::release) and check client ip against data group and then drop/reject it when matching. data group is needed because you can add/modify/remove ip in data group without changing irule. as you may know, configuration change does not affect existing connection.
sol13253: Configuration changes to local traffic objects do not affect existing connections
yeah,I know configuration change doesn’t affect existing connection,but datagroup in irule can work around this. tcp:collect/tcp:release? does it affect perfermance? I assume tcp::collect only collect payload in layer7 or in layer4(not sure),not ip address which locates in layer3
e.g.
configuration
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:22
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
tcp { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 5
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
members {
200.200.200.101:22 {
address 200.200.200.101
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm data-group internal blacklist
ltm data-group internal blacklist {
type ip
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
log local0. "\[class get blacklist\]=[class get blacklist]"
when CLIENT_DATA {
if { [class match -- [IP::client_addr] equals blacklist] } {
log local0. "reject"
reject
return
TCP::release
TCP::collect
when SERVER_CONNECTED {
log local0. ""
clientside {
TCP::collect
/var/log/ltm
[root@ve11c:Active:In Sync] config tail -f /var/log/ltm
May 8 16:28:15 ve11c info tmm[15145]: Rule /Common/qux : [class get blacklist]=
May 8 16:28:16 ve11c info tmm[15145]: Rule /Common/qux : [class get blacklist]=
May 8 16:28:18 ve11c info tmm[15145]: Rule /Common/qux : [class get blacklist]=
May 8 16:28:20 ve11c info tmm[15145]: Rule /Common/qux : [class get blacklist]=
May 8 16:28:21 ve11c info tmm[15145]: Rule /Common/qux : [class get blacklist]=
May 8 16:28:22 ve11c info tmm[15145]: Rule /Common/qux : [class get blacklist]=
May 8 16:28:28 ve11c info tmm[15145]: Rule /Common/qux : [class get blacklist]=192.168.206.0/23 {}
May 8 16:28:28 ve11c info tmm[15145]: Rule /Common/qux : reject
nothing has no impact. ![]()
e.g.
configuration
ltm virtual bar {
ip-protocol tcp
pool foo
profiles {
tcp { }
rules {
qux
source 0.0.0.0/0
type automap
vs-index 5
ltm pool foo {
members {
type ip
ltm rule qux {
when CLIENT_DATA {
reject
return
TCP::release
TCP::collect
log local0. ""
clientside {
TCP::collect
/var/log/ltm
ha,I don’t understand this,need time to pick it up.
