As we migrated to Modern Auth (OAuth) we’d like to retire legacy authentication protocols on our external interfaces for Exchange
We have a separate iApp for the external traffic where we included an iRule to block Basic Auth requests (this works)
The same rule should also remove the www-authenticate header on responses for supporting Basic in case this is offered by the server after a 401.
As this triggers this accidently removes all headers and not only the one containing ‘Basic’ in the example below
Hoping somebody here has done anything similar already in the past?
if { [string tolower [HTTP::header values “Authorization”]] contains “basic”} {
drop
when HTTP_RESPONSE {
if {[HTTP::status] == 401} {
foreach header_name [HTTP::header names] {
if { [string tolower [HTTP::header value $header_name]] contains “basic”} {
HTTP::header remove $header_name}
