Bits in/out difference
Hi..
Although the two pool members have the same number of connections, why are the bits in and out values different?
so find below the difference:
In: The sum of all ingress traffic Out: The sum of all egress traffic
the size difference between incoming and outgoing packets is normal because the server response is much larger than your request.
for more details:
Hope it’s clear. let me know if you need more details. regards,
