There’s not a lot of information out there on how to scan binary tcp data for specific matches. We were having a problem with an app hang if SSL Server hello message went missing on the client side of bigip. I figured I’d write an iRule to ‘replicate’ the packet loss by inserting another bigip between the client and the real VIP and have it ‘lose’ packets every once in a while. This gives the app time to start and then break later on.
The below iRule contains bit’s and pieces of ideas from several different iRules.
when RULE_INIT {
set a counter so we can selectively drop packets
set ::COUNTER 0
when CLIENT_ACCEPTED {
grab the client IP and port for later logging
set client_ip [IP::client_addr]
set client_port [TCP::remote_port]
when SERVER_CONNECTED {
I’m not sure why I have to put this line here but it’s needed
TCP::collect
when SERVER_DATA {
read in the data from the server side
TCP::collect
set a variable to whatever the data is
set payload [TCP::payload]
next section identifies the packet we want to ‘drop’
scan the data, take the first 12 bytes and set variable data
binary scan $payload H12 data
16 is an ssl handshake, 0300 is version 3, the next two bytes
are the length, we skip them.
the last bytes is the type, 02 is a Server Hello
if { ( $data starts_with “160300”) && ( $data ends_with “02”) } {
if we made it here, we’ve got an SSL server hello packet
if { $::COUNTER equals “5” } {
The global counter is at 5, reset the counter to 0
set ::COUNTER 0
Log that we are about to ‘drop’ the packet
log local0. "dropping SSL session $client_ip:$client_port "
terminate processing…bye bye packet
return
If you are here, we have an SSL server hello but
we are going to let this one through
log local0. “matched an SSL server hello but letting it through”
increment the global counter
incr ::COUNTER +1
log the counter state just to see that the rule matched ‘stuff’
log local0. “COUNTER is now $::COUNTER”
if you made it this far, it was not an SSL server hello
or it was not time to drop this particular hello
release the data to the client side
TCP::release
