bigstart restart now logs not being written
I successfully completed a
bigstart restart
sequence ( logs show everything coming back up as expected ).
However, now logs that should be written by my irule are not being written.
Also, I’ve been restarting BIG-IP to force data-group-files to be re-cached, but is there a better way ?
Apparently there is a delay of some sort -- perhaps first flush to disk does not occur until buffer is filled by a certain amount.
You can probably just reload the config: tmsh load sys config
