Hey all, I have to create a number of pools and virtual servers running on an LTM just upgraded to 10.2. Is there a tutorial or a sample script out there that I can reference that uses the bigpipe command?
I am trying this command, but it kicks me out to a > prompt:
b pool ${mypool_HTTPS ‘{lb method member least conn monitor all bigipaspx_https member 10.5.6.30:443 member 10.5.6.31:443}’
I know the basic commands, to do this but would like to see where to specify the advanced configuration options.
This next one is for building a GTM configuration, but the process would be very similar for building pools and a virtual server if you swapped out some commands:
Thanks for the reply Jason, I will most certainly look into tmsh scripting, but this is more of an urgent need since I have to get everything created this evening. Can someone help me with the bigpipe commands to just get me over the hump?
Awesome, so my syntax was a little incorrect, thanks Jason. Can you help with my virtual syntax? I am using the following, but I can’t figure out how to specify profiles, so this is giving me an error that I need to specify the HTTP ofr FASTHTTP profile:
For bigpipe format, you can check an existing object in the bigip.conf or bigip_base.conf. As Jason pointed out a while ago, you can escape the new lines using single quotes. So if the virtual server looks like this in the bigip.conf:
