bigpipe load / Restore archive interrupt service?
Hi
Did command “bigpipe load” or “tmsh load sys config” or Restore Archive interrupt service on BIG-IP ? (V.10.2.4)
I’m looking for anything that make BIG-IP service interrupt or downtime.
Thank you
i never tested but this is what askf5 sol says.
The BIG-IP system will require a configuration reload, which may result in a brief interruption in traffic processing.
Does that mean If I using BIG-IP LTM Active-Active mode and perform Sync configuration , It will make a brief interruption in traffic processing too ? Cause BIG-IP must perform configuration load at unit which I sync to .
