Bigpipe Command to create pool with setting
I need to create a pool with the following result- Which Bigpipe command will accomplish this ?
pool YAYA_3105 {
lb method member ratio
monitor all gateway_icmp
members {
172.16.20.1:3501 {
ratio 10
172.116.20.2:3501 {
ratio 10
Why the following is not doing the job. What am I missing?
b pool YAYA_3105 { lb method member ratio monitor all gateway_icmp members { 172.16.20.1:3501 { ratio 10 } 172.16.20.2:3501 { ratio 10 } } }
nvm, thanks anyway
the correct config is :
b pool YAYA_3501 { lb method member ratio monitor all gateway_icmp members { 172.16.10.1:3501 { ratio 10 } } add }
b pool YAYA_3501 { lb method member ratio monitor all gateway_icmp members { 172.16.10.2:3501 { ratio 10 } } add }
