BigIQ 5.3 clustering between datacenters
Trying to figure out if a BigIQ 5.3 cluster can be created when the BigIQ devices are in entirely different locations and in different subnets. The guides I have seen so far just reference going through the steps of adding the second device as a peer to the first device and whatnot, but don’t saying anything if there is or is not a requirement for them to have a common network between them.
Thanks in advance!
Greetings,
In reading the following, it seems you just need to pick the same interface type on each BIG-IQ. So, for your configuration, if you pick the management interface on both devices, your requirement should work:
https://support.f5.com/csp/article/K15612ha_peers
Hope this helps!
Kevin
