BIGIP VE under Fusion Pro 10
trying to install a BIGIP VE on VMware Fusion 10 (Trial). (I originally used Parallels for Mac, but I couldn’t license it as it was identified as platform “”)
I’m following this guide: DevCentral
To rule out mistakes, I applied this interface config: DevCentral
However, when I try to run
tmsh create net vlan external interfaces add { 1.1 { untagged } }
I get:
01070256: Requested VLAN member (1.1) is not valid
tmsh show net interface all
: Imgur: The magic of the Internet
On my laptop:
$ ifconfig | grep vmnet
vmnet1: flags=8863 mtu 1500
vmnet2: flags=8863 mtu 1500
vmnet3: flags=8863 mtu 1500
vmnet4: flags=8863 mtu 1500
vmnet5: flags=8863 mtu 1500
vmnet6: flags=8863 mtu 1500
vmnet7: flags=8863 mtu 1500
vmnet8: flags=8863 mtu 1500
vmnet9: flags=8863 mtu 1500
vmnet10: flags=8863 mtu 1500
vmnet11: flags=8863 mtu 1500
From macOS Terminal:
cat /Library/Preferences/VMware\ Fusion/networking
What is your output? You should see a bunch of stuff similar to this:
VERSION=1,0
answer VNET_1_DHCP yes
answer VNET_1_DHCP_CFG_HASH 4096360A66F5587A10B999CC4758A010E918F6B6
answer VNET_1_HOSTONLY_NETMASK 255.255.255.0
answer VNET_1_HOSTONLY_SUBNET 192.168.186.0
answer VNET_1_VIRTUAL_ADAPTER yes
answer VNET_2_DHCP yes
answer VNET_2_DHCP_CFG_HASH EDE43DD0AE3EC6967BE41D250865C4010F7B01E9
answer VNET_2_HOSTONLY_NETMASK 255.255.255.0
answer VNET_2_HOSTONLY_SUBNET 10.128.1.0
answer VNET_2_VIRTUAL_ADAPTER yes
From the page you mentioned, I put in this:
VERSION=1,0
answer VNET_2_HOSTONLY_SUBNET 192.168.102.0
answer VNET_2_VIRTUAL_ADAPTER_ADDR 192.168.102.1
answer VNET_3_HOSTONLY_NETMASK 255.255.255.0
answer VNET_3_HOSTONLY_SUBNET 192.168.103.0
answer VNET_3_VIRTUAL_ADAPTER yes
answer VNET_3_VIRTUAL_ADAPTER_ADDR 192.168.103.1
answer VNET_4_HOSTONLY_NETMASK 255.255.255.0
answer VNET_4_HOSTONLY_SUBNET 192.168.104.0
answer VNET_4_VIRTUAL_ADAPTER yes
answer VNET_4_VIRTUAL_ADAPTER_ADDR 192.168.104.1
answer VNET_5_HOSTONLY_NETMASK 255.255.255.0
answer VNET_5_HOSTONLY_SUBNET 192.168.105.0
answer VNET_5_VIRTUAL_ADAPTER yes
answer VNET_5_VIRTUAL_ADAPTER_ADDR 192.168.105.1
answer VNET_6_HOSTONLY_NETMASK 255.255.255.0
answer VNET_6_HOSTONLY_SUBNET 192.168.106.0
answer VNET_6_VIRTUAL_ADAPTER yes
answer VNET_6_VIRTUAL_ADAPTER_ADDR 192.168.106.1
answer VNET_7_HOSTONLY_NETMASK 255.255.255.0
answer VNET_7_HOSTONLY_SUBNET 192.168.107.0
answer VNET_7_VIRTUAL_ADAPTER yes
answer VNET_7_VIRTUAL_ADAPTER_ADDR 192.168.107.1a
Hrm. If you configure the interfaces from the virtual machine settings, are they available to modify? Can you go into “Network Adapter 2” and select a vmnetX? My worry is that Fusion in a trial may not let you use more than X adapters.
Hmmm, I suppose not? : Imgur: The magic of the Internet
If that’s the case then you should be able to use mgmt and the 1.0 interface if the trial does not allow you to add further network adapters.
Just use the 1.0 interface to hairpin traffic, not an uncommon solution in smaller cloud deployments. Traffic will go in and exit that same interface but you can still config virtual servers and play around with the features.
Wait, I misread that. I can add more interfaces; Imgur: The magic of the Internet
It’s available, I added a bunch of vmnet interfaces in my previous screenshot as proof.
Sorry, missed that. If you restart BIG-IP following the additional interface creation do the interfaces show as uninitialized?
Hello @Chase, I rebooted the F5 several times
your bigip shows that it has not activated its license yet per screenshot. I suggest you activate the license first then move on to configuration.
The commands do work without requiring activation as I just tested yesterday on 13.x.
@NiHo - Any chance you want to try to reimport the OVA again now that the interfaces exist? I still cannot promise anything with Fusion Trial. VMWare suggested to call in which was not super helpful.
