Dear all,
our VE-LAB edition under 11.4.1 is showing the following ssh system prompt:
[root@bigip1:ModuleNotLicensed:Active:Standalone]
What does "ModuleNotLicensed" mean
respectively which module is not licensed?
Many thanks for any tip!
Rainer
can you check system > resource provisioning?
o.k. There are some unlicensed module like LC/EM/CGNAT but on our LTM 4000 under 11.5.1 there are the same unlicensed module but the ssh prompt shows NOT this “ModuleNotLicensed” phrase.
can you post the provisioning screenshot or license and provision tmsh output?
tmsh show sys license
tmsh list sys provision
show sys license Sys::License Licensed Version 11.2.1 Registration key xxxxxxxxxxxxxxxxxxxxxxxxxxx Licensed On 2012/10/26 Service Check Date 2013/10/25 Platform ID Z100 Active Modules BIG-IP, LAB(LTM,AFM,APM,ASM,AM, DNS, PSM,GTM),VE (ZGHAIIY-OFDMDMC) IPV6 Gateway Rate Shaping Ram Cache 50 MBPS COMPRESSION SSL, 500 TPS Per Core Client Authentication DNSSEC WBA, VE WOM, VE ASM, VE PSM, VE Anti-Virus Checks Base Endpoint Security Checks Firewall Checks Network Access Secure Virtual Keyboard APM, Web Application Machine Certificate Checks Protected Workspace Max Compression, VE Remote Desktop App Tunnel SSL, Max TPS, VE Routing Bundle, VE Advanced LTM Protocols, VE AFM, VE Acceleration Manager, VE DNS Services DNS Rate Fallback, Unlimited DNS Licensed Objects, Unlimited DNS Rate Limit, Unlimited QPS External Interface and Network HSM, VE SDN Services, VE SSL, Forward Proxy, VE AAM, Upgrade from WAM, (v11.4 & later) GTM, VE (LNHJIJQ-HSZBVJC) IPV6 Gateway Ram Cache STP DNS Express Routing Bundle, VE DNS Rate Fallback, Unlimited DNS Licensed Objects, Unlimited DNS Rate Limit, Unlimited QPS GTM Rate Fallback, (UNLIMITED) GTM Licensed Objects, Unlimited GTM Rate, Unlimited list sys provision sys provision afm { } sys provision am { } sys provision apm { level nominal } sys provision asm { level nominal } sys provision avr { } sys provision gtm { } sys provision lc { } sys provision ltm { level nominal } sys provision pem { } sys provision psm { }
it seems the warning is due to apm lab license which is limited to 10 users.
