BigIp Upgade vs hardware driver
Hi!
I am planning to upgrade a single i4600 from 12.1.2 to BIGIP-12.1.3.0.0.378. The device contains 4 pieces 1000BASE-T Copper Ethernet transceiver (SKU: F5-UPG-SFPC-RSKU). An additional hardware driver was installed by "; article in order to BigIp can use the medias. My questions: What will happen when I upgrade the device? Do I need to install again the hardware driver?
Thanks for the answer.
You don’t have to. From your description I believe you are about to update to a higher hotfix. This Resource will be helpful.
Cheers…
