I’m new here and not very familiar with F5 products, however I’ve been tasked in a project to query our BigIP devices via snmp to get some much needed data. More accurately, I want to access the ltm pool and get information like which IP addresses is this device load balancing.
After doing some research I found that the F5 BIGIP local MIB specifies this OID ltmPools->(.1.3.6.1.4.1.3375.2.2.5) as a good starting point. However after an snmpwalk this OID is nowhere to be found, infact there are just one OID found with an address of 3375.
Digging deeper I find that there are some OIDs where the actual OID-address contains IP addresses but no values which make me wonder if there is something wrong or if I’m working based on wrong information.
How should I go about finding the information I need? Any pointers are much appreciated!
In the context of the snmpget command you will see the complete numeric OID followed by the string representation and type:value.
This information can now be used to read or to modify the specific parameter (i.e. to put the poolmember 10.131.131.170:389 in pool_ldap_search in forced down (via adding “i 20”):
snmpset -c public localhost .1.3.6.1.4.1.3375.2.2.5.3.2.1.10.24.47.67.111.109.109.111.110.47.112.111.111.108.95.108.100.97.112.95.115.101.97.114.99.104.22.47.67.111.109.109.111.110.47.49.48.46.49.51.49.46.49.51.49.46.49.55.48.389 i 20
F5-BIGIP-LOCAL-MIB::ltmPoolMemberMonitorState."/Common/pool_ldap_search"."/Common/10.131.131.170".389 = INTEGER: forced-down(20)
A list of possible states can be retrieved from the F5 MIB files (i.e. F5-BIGIP-LOCAL-MIB):
