bigip_pool Ansible module - can't find imported module - cmp_str_with_none.py
I am running into an issue with AWX and trying to run some of the F5 ansible modules.  I am getting an error that the module can’t find a support pip module.  Below is the error.
“msg”: “Could not find imported module support code for bigip_pool.  Looked for either cmp_str_with_none.py or compare.py”,
“_ansible_no_log”: false
When.I run this code from a local server, it runs fine.  I am trying to figure out what pip module I am missing.
In the bigip_pool.py, I see the following lines:
try:
from library.module_utils.network.f5.bigip import F5RestClient
from library.module_utils.network.f5.common import F5ModuleError
from library.module_utils.network.f5.common import AnsibleF5Parameters
from library.module_utils.network.f5.common import fq_name
from library.module_utils.network.f5.common import f5_argument_spec
from library.module_utils.network.f5.common import transform_name
from library.module_utils.network.f5.compare import cmp_str_with_none
from library.module_utils.network.f5.icontrol import TransactionContextManager
Anyone have any ideas on what pip module I am missing?
