bigip hardening
Hi all,
how can i harden f5 bigip which is facing the internet directly for specific ip address
to manage the device?
management port is not in use , management is used via the interface facing the internet
on port 1.1 with self ip 1.1.1.1/28 for example.
using port lockdown there’s no option to limit ip address
please advise
sol5380: Specifying allowable IP ranges for SSH access
sol7448: Restricting access to the Configuration utility by source IP address
hope this helps.
hi nitass,
does sol7448 support v11.0/1 ?
i think it is applicable but we have to use tmsh instead.
root@ve1100(Active)(/Common)(tmos) show sys version
Sys::Version
Main Package
  Product  BIG-IP
  Version  11.1.0
  Build    1943.0
  Edition  Final
  Date     Sun Nov 20 18:27:50 PST 2011
root@ve1100(Active)(/Common)(tmos) list sys httpd all-properties
sys httpd {
    allow { All }
    auth-name BIG-IP
    auth-pam-dashboard-timeout off
    auth-pam-idle-timeout 1200
    description none
    fastcgi-timeout 300
    hostname-lookup off
    include none
    log-level warn
    max-clients 10
    ssl-certchainfile none
    ssl-certfile /etc/httpd/conf/ssl.crt/server.crt
    ssl-certkeyfile /etc/httpd/conf/ssl.key/server.key
    ssl-ciphersuite ALL:!ADH:!EXPORT:!eNULL:!MD5:!DES:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2
    ssl-include none
i cant modify the allow { All } value
can you assist?
e.g.
sys httpd {
    allow { All }
    auth-name BIG-IP
    description none
    fastcgi-timeout 300
    hostname-lookup off
    include none
    log-level warn
    max-clients 10
    ssl-include none
root@ve1100(Active)(/Common)(tmos) modify sys httpd allow replace-all-with { 192.168.206.0/24 }
sys httpd {
    allow { 192.168.206.0/24 }
Hi all,
I came across this question this morning and looked forward to the feedback. I’ve used the info here to help secure our LTMS and GTMs.
I’d like to take this further maybe and talk about locking the system down even further - if possible that is. We’re currently going through a pci compliance project. For those of you who don’t know about pci it’s bascially a security best practice process. Anyway does anyone know of any guidelines from F5 or elsewhere that helps get our kit locked down even further?
I’ve yet to carry out a port scan on the kit so I’m not sure what is open, nor am I sure about the implementation of the protocols and services available.
We use F5 kit quite heavily in our infrastructure so hopefully this won’t be too painful. Any help, as always, is greatly appreciated.
Thanks,
Joe
this is additional information but not sure if it is useful.
sol13092: Overview: Securing access to the BIG-IP system
hope this helps.
I think you could also check the configuration of each vserver.
One thing to specify to tighten it down further is the allowed vlan property. So you will only expose the vserver for the proper interfaces. But this will also depend on if you use the F5 as a pure loadbalancer or if you use it as a router aswell.
Even if you use it as a router aswell you can then specify for which vlans the forwarding-ip vserver should be exposed.
