Is there anything that could be done to obscure the client logging once the endpoint security client-side checks begin. It would be possible to reverse engineer the endpoint security checks, eg windows registry key check from the edge client debug logs. With the citrix receiver client and netscaler the checks are logged as codes rather then what is being checked so are obscure.
Even moving the AD/LDAP authentication to start still could allow a rogue user to login a random device with there VPN credentials and run through endpoint security client-side checks, adding the windows registry key, windows processes, firewall (versions) etc (excluding the machine certificate check).
So like the citrix receiver client is it possible to obscure the checks?
