Can anybody help me with the above issue (attached in the screenshot).
in one of the device, i am not able to access the GUI and shows unable to contact the device, it occurs very often.
Can some one post the suggestions for fix.
Thanks in advance.
-SAM
Hi Sam, I guess, currently you are running 11.3 version of F5. Due to sod leakage(switch over daemon), it takes longer time to enter in f5. To mitigate this issue please install hotfix 11.3.0 HF10(Link).
Hello Samir,
Thanks for the response, device is running with 11.6.0
