how to do waf cleanup to save space ?
Hello, You want to remove the ASM module or clean the sql database? For removig the ASM deprovision it. You can check 404 Page not found | BIG-IP Documentation , if you have small memory not disk space you can set the ASM module to nominal and the other modules also can be set to nominal as this may also help.
For to clean the ASM database you can see myF5 and for the AVR myF5 . I still suggest if you have disk space issue to first check myF5 as it could a bug like myF5 or something else.
Also keep in mind that for F5 virtual editions or F5 vCMP quests you can manually increase the disk space myF5 and myF5
Be carefull if the ASM is used in production to protect the traffic.
