Hello,
I have a problem with my BigIP, the config sync isn’t working :
Checking configuration on local system and peer system...
Peer's IP address: 192.168.168.2
Synchronizing Master Keys...
Saving active configuration...
Configsync Mode: Push
Transferring UCS to peer...
Installing UCS on peer...
OperationFailed exception:
Primary error : 16908289
Secondary error: 0
Error text : Error trying to determine whether configuration is encrypted or not.
Obtaining results of remote configuration installation...
Secondary error: 0
Error text : Error opening file for read operations
Error obtaining results of remote configuration installation.
Error installing UCS on peer.
Transport and install failed
Error running config sync all.
BIGpipe parsing error:
01110001:3: Error running config sync all
It worked 3 days ago after adding servers in pool using tmsh, saving the config and using the ewb interface to sync the config, but today, it didn’t work.
I tried with the bigpipe “config sync all command” but it is the same.
The ping between peer work fine, the 443 port is open, and it seems the file is correctly transfered but it doesn’t install on the remote peer… Here is the file i can see on the remote peer when i try to sync :
-rw-r--r-- 1 root apache 768K May 27 09:56 __sync_remote__.ucs
I work in an hospital and the bigip are really critical and have many application on it. If someone can help me find a solution, it would be really great
Best Regard
Jérôme
Here are the “csTest.pl -vv” on both peer :
Active :
[root@lb-ensmgt:Active] tmp csTest.pl --v
Status of daemons:
Warning: BigDB daemon (bigdbd) is not running.
Configsync configuration:
Failover address (Self): 192.168.168.1
Peer IP address: 192.168.168.2
Configsync port: 443
Configsync username: admin
Acceptable time difference: 600 seconds
Configsync auto detect status:
3 - Config modified on both systems, manual intervention required
Last change (Self): 05/27/2014 09:55:50 (1401177350)
Peer state is: known
Last change (Peer): 05/26/2014 16:00:45 (1401112845)
Last configsync: 05/23/2014 11:18:53 (1400836733)
Peer update interval: 30 (seconds)
Network connection status:
Local system is listening on configsync port (443).
Ping test to peer 192.168.168.2 succeeded.
SOAP connection test to peer 192.168.168.2 succeeded.
SOAP time difference check:
Within the acceptable range.
Product version test:
Major and minor product versions are identical. The maintenance
versions are different.
The configsync tests completed successfully. You can run this
diagnostic tool on the peer 192.168.168.2 for further information.
Passive :
[root@lb-opamgt:Standby] tmp csTest.pl --v
Status of daemons:
Failover address (Self): 192.168.168.2
Peer IP address: 192.168.168.1
Last change (Self): 05/26/2014 16:00:43 (1401112843)
Last change (Peer): 05/27/2014 09:55:51 (1401177351)
Last configsync: 05/23/2014 11:18:52 (1400836732)
Ping test to peer 192.168.168.1 succeeded.
SOAP connection test to peer 192.168.168.1 succeeded.
diagnostic tool on the peer 192.168.168.1 for further information.
I tried manual sync, but it doesn’t work too : The result of the install on the remote peer :
[root@lb-opamgt:Standby] ~ bigpipe config install /var/local/ucs/lb-ensmgt.hcuge.ch-2014-05-27.ucs
mkdir: cannot create directory `/var/tmp/cert_temp': Read-only file system
/tmp/cs_save_pre_script: line 41: cd: /var/tmp/cert_temp: No such file or directory
/tmp/cs_save_pre_script: line 61: cd: /var/tmp/cert_temp: No such file or directory
/tmp/cs_save_pre_script: line 77: cd: /var/tmp/cert_temp: No such file or directory
mkdir: cannot create directory `/var/tmp/gtm_tmp': Read-only file system
/tmp/cs_save_pre_script: line 105: cd: /var/tmp/gtm_tmp/gtm: No such file or directory
/tmp/cs_save_pre_script: line 108: cd: /var/tmp/gtm_tmp/gtm: No such file or directory
/tmp/cs_save_pre_script: line 116: cd: /var/tmp/gtm_tmp/big3d: No such file or directory
mkdir: cannot create directory `/var/tmp/em_db_temp': Read-only file system
Error creating package
Error backing up current configuration.
mkdir: cannot create directory `/var/tmp/ucs.20890': Read-only file system
Fatal: executing: mkdir -p /var/tmp/ucs.20890
Operation aborted.
/tmp/configsync.spec: Error installing package
Config install aborted.
01110001:3: Error running config install
have you tried to restart standby unit and then configsync again?
anyway, i think it may be good to open a support case before rebooting just in case if Support needs any data which may be gone after rebooting.
It seems to be a problem with the remote peer hardrive firmware :
[root@lb-opamgt:Standby] tmp hdparm -I /dev/sda | grep Firmware
Firmware Revision: 04.04V05
[root@lb-opamgt:Standby] tmp eud_info
12.8.0.799.0
The other box has its firmware version at : 04.04v06 and is ok
The question is : Can i update the EUD on only one peer? (the box will have a différent version of EUD…)
eud and hard disk firmware version can be different from peer unit.
Thanks for the quick answer.
I’m opening a support case as you suggested if they need some information before restarting the box.
After a few more investigation, i found those logs in the remote peer :
local/lb-opamgt err statsd[3767]: 011b0600:3: Error 'opening '/var/rrd/connections': Read-only file system' during rrd_update for rrd file '/var/rrd/connections'
It match this issue : 404 Page not found | BIG-IP Documentation
I’m still waiting for f5 support answer to plan an intervention on the remote peer.
I updated the HDD firmware this morning (The support confirmed about this issue). Now the problem is solved. The S.M.A.R.T. test passed successfully after the upgrade.
Thanks for the help,
Jérôme
Can you pls describe the steps involved for this upgradation.
Also, How to perform the S.M.A.R.T tes.
Thanks in advance
Thanks Amit
I think the links below give the answers to all your questions :
Download the EUD : Page has moved
Create a USB bootable Flash drive with EUD on it : https://devcentral.f5.com/wiki/AdvDesignConfig.create_eud_on_usb_from_windows.ashx?NoRedirect=1
How to use the EUD : myF5
Let me know if you have further question
Thanks Jerome,
My EUD is 12.8.1 or above, i guess no need to upgrade complete EUD , could i upgrade only hard drive firmware?
I just checked on my bigip, it seems the eud is still at the same version (12.8.0.799.0), so you may be able to upgrade only the HDD firmware
So, Removing of all network cables & turn the device power oFF & ON is required to get the EUD option ? or direct reboot command will restart and give me the option to select EUD ?
If i remember well, i removed all the network cable, powered off my bigip, the boot on the usb device and upgraded my firmware using the EUD options.
After that, i rebooted the device with all the network cable on it.
