bigd[4977] 01060111
This error is happening countinously every 4 seconds
Open SSL error - error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol.
May be this will help you https://devcentral.f5.com/questions/open-ssl-error-on-ltm-logs-since-v11-upgrade
Do you have a monitor applied that is using SSL?
Thank you for your suggestion. I had a https monitor, monitoring http pool members. I change the monitor to http and the error stopped. Thanks
