Problem this snippet solves:
Add, list or delete a Tenant within BIG-IQ
Code :
#!/usr/bin/python
import argparse
import json
import logging
import sys
import restapi;
DEFAULT_BIGIQ_USER = "admin"
DEFAULT_BIGIQ_PASSWORD = "admin"
DEFAULT_BIGIQ_ACTION = "List"
DEFAULT_BIGIQ_TENANT_NAME = "My-Tenant"
DEFAULT_BIGIQ_CONNECTOR_NAME = "My-Tenant-Connector"
DEFAULT_BIGIQ_TENANT_USER= "MyTenant"
LOG = logging.getLogger(__name__)
# Loads a JSON file.
def load_json_file(name):
with file(name) as f:
json_data = json.load(f)
if json_data:
json_data = json.dumps(json_data)
return json_data
# Prints a line separator (for easy viewing).
def print_separator():
print("-" * 80)
# Validates the HTTP/REST result.
def validate_result(result, verbose=False):
# Any result beyond HTTP 400 is considered an error.
if ((result == None) or (result[0] >= restapi.HTTP_400)):
sys.exit(1)
if verbose:
for i in range (1, len(result)):
LOG.info(result[i])
# Modifies a field of a JSON string and returns it as a string
def modify_json(json_string, field_to_modify, new_value):
json_data = json.loads(json_string)
if json_data == None:
sys.exit(1)
json_data[field_to_modify] = new_value
return json.dumps(json_data)
#Retrieve connector link to include it into the tenant to be created
def retrieve_connector_link(list_connectors, connector_name):
result = []
for i in range (1, len(list_connectors)):
connector_name_ = list_connectors[i]['items'][0]['name']
if (connector_name == connector_name_):
connector_link = {'link':list_connectors[i]['items'][0]['selfLink']}
result.append(connector_link)
print(result)
return(result)
# Runs the BIG-IQ cloud API test suite.
def run_bigiq_tests(bigiq_address,
action=DEFAULT_BIGIQ_ACTION,
tenant_name=DEFAULT_BIGIQ_TENANT_NAME,
connector_name=DEFAULT_BIGIQ_CONNECTOR_NAME,
tenant_user=DEFAULT_BIGIQ_TENANT_USER,
bigiq_user=DEFAULT_BIGIQ_USER,
bigiq_password=DEFAULT_BIGIQ_PASSWORD,
verbose=False):
LOG.info("Running BIG-IQ Tenant tests...")
# Initialize cloud API tester.
LOG.info("BIG-IQ: Initializing cloud API shim...")
cloud_api = restapi.RestApi(host=bigiq_address,
user=bigiq_user,
password=bigiq_password)
LOG.info("BIG-IQ: Cloud API shim successfully initialized.")
if (action == "Delete"):
result = cloud_api.delete_tenant(tenant_name)
validate_result(result, verbose)
LOG.info("BIG-IQ: Tenant successfully deleted")
if (action == "List"):
# BIG-IQ: query tenants list
LOG.info("BIG-IQ: Querying list of tenants...")
result = cloud_api.get_all_tenants()
validate_result(result, True)
LOG.info("BIG-IQ: Device tenant list successfully retrieved.")
if (action == "Create"):
# BIG-IQ: create tenant.
LOG.info("BIG-IQ: Creating tenant...")
# BIG-IQ: Retrieve connetor link
list_connectors = cloud_api.get_local_connectors()
local_connector_link = retrieve_connector_link(list_connectors, connector_name)
# BIG-IQ: Retieve user link
user_information = cloud_api.get_user(tenant_user)
print(user_information)
user_information_link = {'link':user_information[1]['selfLink']}
print(user_information_link)
# BIG-IQ: Define the user role for this partition ... done by appending CloudTenantAdministrator to the tenant name
user_role_link = {'link':'https://localhost/mgmt/shared/authz/roles/CloudTenantAdministrator_' + tenant_name}
print(user_role_link)
tenant_json_string = modify_json(load_json_file("./bigiq_create_tenant.json"),
'cloudConnectorReferences',
local_connector_link)
tenant_json_string = modify_json(tenant_json_string,
'userReference',
'roleReference',
user_role_link)
print (tenant_json_string)
result = cloud_api.create_tenant(tenant_json_string)
LOG.info("BIG-IQ: Tenant successfully created.")
# Initializes logging.
def init_logging(level=logging.INFO):
log_format = '%(asctime)-15s: %(funcName)s(): %(message)s'
logging.basicConfig(format=log_format, level=level)
# Main entry point
def main():
parser = argparse.ArgumentParser(description="Runs various REST-API functional tests")
parser.add_argument('-v', '--verbose', action='store_true', default=False)
parser.add_argument('--tenant-name', default=DEFAULT_BIGIQ_TENANT_NAME)
parser.add_argument('--connector-name', default=DEFAULT_BIGIQ_CONNECTOR_NAME)
parser.add_argument('--tenant-user', default=DEFAULT_BIGIQ_TENANT_USER)
parser.add_argument('--bigiq-address', required=True)
parser.add_argument('--bigiq-user', default=DEFAULT_BIGIQ_USER)
parser.add_argument('--bigiq-password', default=DEFAULT_BIGIQ_PASSWORD)
parser.add_argument('--action', default=DEFAULT_BIGIQ_ACTION)
args = parser.parse_args()
log_level = logging.INFO
if (args.verbose):
log_level = logging.DEBUG
init_logging(log_level)
# BIG-IQ tests.
run_bigiq_tests(bigiq_address=args.bigiq_address,
action=args.action,
tenant_name=args.tenant_name,
connector_name=args.connector_name,
tenant_user=args.tenant_user,
bigiq_user=args.bigiq_user,
bigiq_password=args.bigiq_password,
verbose=args.verbose)
LOG.info("OK. Done testing.")
# Main entry point launcher.
if __name__ == '__main__':
main()
