Just testing BIG-IQ 5.2.0 and BIG-IP 13.0.0HF2 VE.
Scenario:
- BIG-IP Re-discovered
- Results Re-imported - no messages about conflicts between BIG-IQ and BIG-IP
- Evaluation job created with settings as below:
- After job is performed I have info about Removed objects like below:
I did check both BIG-IP - all objects listed as Removed are existing on BIG-IP - so this part is true. I as well did search on BIG-IQ in Configuration → Profiles (most objects listed as Removed are profiles) - all listed objects can be found on BIG-IQ.
I don’t understand why Evaluation list objects as Removed - not existing on BIG-IQ.
First of all those objects exists on BIG-IQ.
Second, even those objects did not exist then after sucesfull Re-discover and Re-import of BIG-IP should be created on BIG-IQ.
So what Am I missing here?
Piotr
