Is it possible to have BIG-IP with modules in different versions? For example, BIG-IP version is 11.60 but install different modules with different versions in “Resource Provisoning?” For example, install ASM 12.0 but LTM remains 11.6.
Thanks!!
Thanks!!
No. It’s not. The modules are already present, they don’t get installed separately. It’s purely a license that enables/disables them. So if you install v12 LTM you get v12 GTM, APM, ASM etc.
H
