BIG IP Virtual Edition 13.1.1 Installation & Configuration
Hello I have some services that i need to published on an intranet. My environement is composed with intranet, firewall, BIG-IP virtual Edition, and servers . The layer 3 routing is on the firewall. Below are my questions: do i need to create involved dedicated vlan of applications published? how can i create specific partition on my BIG-IP VE? Also how can i configure HA for my cluster devices? Platform is LTM
Thanks in advance for your reply
Marieme
Hello Marieme
Do I need to create involved dedicated vlan of applications published?
Well this depends on how your network design looks. You can use the BIG-IP in a One-arm mode where your traffic will work in the following way:
Incoming Traffic
→ [Firewall] → [BIG-IP] → [Firewall] → [Servers]
Return Traffic
→ [Servers] → [Firewall] → [BIG-IP] → [Firewall]
In this case you are forced to use SNAT in order to translate the source IP address to one that is owned by the BIG-IP device.
So no, you’re not forced to create additional VLANs and have the pool members directly attached to the BIG-IP.
How can I create specific partition on my BIG-IP VE?
Manual Chapter: Working with Partitions
Manual Chapter: Creating an Active-Standby Configuration Using the Setup Utility
I hope this helps! :slight_smile:
