BIG-IP VE Deployment using Molcule/Vagrant
I have been trying to setup a BIG-IP VE using Molcule and Vagrant and running into an issue. Has anybody tried this before ? The BIG-IP VM is created but at the end I get an error when it tries to set the hostname using Linux commands vs tmsh.
The following SSH command responded with a non-zero exit status.
Vagrant assumes that this means the command failed!
hostname -F /etc/hostname
Stdout from the command:
Stderr from the command:
Use the TMOS shell utility to make changes to the system configuration.
For more information, see “tmsh help sys global-settings.”
