We have a problem where the user clicks on a link in a webtop which is a native RDP link, their application opens but the connection fails. Tcpdumps show for failed connections client traffic arrives at the F5 but never leaves it. For successful connections they stay up for a long time. We cannot see why they are failing when the backend resource is available and accessible.
VDI debug logs ~ Three Failed VDI access attempts · GitHub
The failed connections just sit there until they time out with the error
"Your computer cannot connect to the Remote Desktop Gateway server.
Contact your network administrator for assistance."
The same native RDP connection can fail, then work, then fail to connect.
Hi Kevin,
On my configuration, Native RDP fails when I configure SSO. it work like a charm without this configuration.
Have you applied the default certificate on VS?
No, using a valid SSL certificate. For everyone elses knowledge … a valid SSL cert is required by native RDP for the MSRDP client to trust the RDP file. This is because APM signs the RDP file with the SSL private key of the virtual server.
** Updated Answer Above **
I am testing the cmp disable with vCPU=2 tomorrow as I am not certain demoting a virtual server to tmm0 will disable threaded execution across tmm0.1/0.2/…
Disabling CMP is a successful workaround. We went back to vCPU = 2 and disabled CMP on the virtual server and all our RDPw/SSO connections are still working.
Summary
Native RDP connections that use SSO variables fail to work reliably.
Version
BIG-IP 13.0.0 HF2
Symptoms
RDP connections intermittently fail to connect. The following message appears when you try to connect to the RDP session.
This occurs under the following conditions
- The virtual servers listens on a specific VLAN.
Workaround
Choose one of the following options:
Option 1: Enabled the virtual server to listen on all VLANS.
Option 2: Disable CMP on the virtual server - see K14358
Option 3: Virtual Edition only, set vCPU to one.
Solution
Hotfix to address this issue.
F5 have come back to us on this issue. Enable the virtual on all VLAN’s. Updated solution posted.
Thank you for the update.
Even if the last workaround is better than previous, in some circumstances, one of previous can help.
I suggest to add in workaround section previous ones (disable sso, disable cmp on VS)
Updated to reflect alternative workarounds.
I am still having this issue running 13.1.0.2, in my situation the vs is running in a non-default route domain.
F5 confirmed we are dealing with bug ID 623036 - Native RDP proxy does not work if Virtual Server is in non-default route domain and CMP enabled. This bug is linked to bug ID6 17929 Support non-default route domains when connecting to other tmm over backplane.
Unfortunately no fix is available yet.
