Big IP sending network trafic info to BigIQ
Hi
I can see under monitoring / events / network security / firewall nothing on my BigIQ. I can see things on my BIG-IP.
I have installed AVR - how do I get firewall events into BigIQ ?
do I need to setup a syslog to the DCD ?
A few questions: do you have a healthy status on the DCD nodes in BIG-IQ? Do you have the stats feature enabled via BIG-IQ for the BIG-IP?
also a change a few versions ago was to have the BIG-IP push statistics to the DCD. So in this case you need to have communications between the BIG-IQ and DCDs and the BIG-IP in both directions: myF5
I’m getting ASM details, but not firewall
Every thing looks health - nothing in BIG-IQ to say there is an issue
Checked the link connectivity is there and there seems to be a link. as I said the ASM logs are making it not the firewall logs!
it looks like I have to setup a firewall logger and send it to the DCD port assigned to network.
Its a pain especially as you pointed out a dedicated IP → DCD link
