I have very simple iRule to show the problem:
set Client_IP [IP::client_addr]
if { ($Client_IP starts_with "x.x.x.x") && ([HTTP::uri] equals "/seed") } {
table set -subtable TABLE "key1" "value1" 30
table set -subtable TABLE "key2" "value2" 15
table set -subtable TABLE "key3" "value3" 45
HTTP::respond 200 content "Done"
TCP::close
return
set key_value "key1"
set key_value2 "key2"
set key_value3 "key3"
set count [table keys -subtable TABLE -count]
Remaining timeout / defined timeout for ${key_value} => [table lookup -notouch -subtable TABLE ${key_value}] [table timeout -subtable TABLE -remaining ${key_value}]/[table timeout -subtable TABLE ${key_value}]
Remaining timeout / defined timeout for ${key_value2} => [table lookup -notouch -subtable TABLE ${key_value2}] [table timeout -subtable TABLE -remaining ${key_value2}]/[table timeout -subtable TABLE ${key_value2}]
Remaining timeout / defined timeout for ${key_value3} => [table lookup -notouch -subtable TABLE ${key_value3}] [table timeout -subtable TABLE -remaining ${key_value3}]/[table timeout -subtable TABLE ${key_value3}]
Count TABLE ${count}"
It looks like table -keys -subtable <tablename> -count don’t work properly:
Remaining timeout / defined timeout for key1 => value1 27/30
Remaining timeout / defined timeout for key2 => value2 12/15
Remaining timeout / defined timeout for key3 => value3 42/45
Count TABLE 0
My expected output would be 3 (as it is not timeouted), not 0.
Can someone check if I am correct? Or tell me how I can count not expired entries in table.
