Hi Everyone, I’m not sure the title is the best for the situation am having but I’ll do my best to describe it.
I have a 1600 box that needs to be reactivated. I setup the management IP and other settings via the LCD and expected to connect to the management port and point my browser to it. I have done everything that should be done, yet, the web interface is not coming up. The device is on the network. It’s responding to pings. I could even SSH into it and login with the admin user ( unfortunately, I don’t have the root password so am limited to Admin level).
I resorted to resetting the entire system by going through the console, unfortunately, the console port is not responding, as in, it is detected by the Terminal Emulator am using to connect but I couldn’t get a login prompt that indicates successful connection.
Please help. What else can I do???
