Big IP Maintenance Page - Multiple Pool Check.
So a user (Lee) was amazing enough to provide me with a maintenance page irule that also include an http header insert. This resolved my problem completely for one of my VIPs, but I have come to find out that another of the VIPs I need a maintenance page for has no pool member directly tied to it. Instead, it has an iRule that calls on different pools based on the URI. This isn’t anything crazy obviously, but I’m not certain how to tie a check for multiple pools into the iRule.
So Lee provided me with the below maintenance page/http header insert rule:
    if {[active_members /partition/poolname_pool] < 1 } {
        HTTP::respond 200 content [ifile get "poolname_MaintenancePage_ifile"] noserver "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate"
        return
    HTTP::header insert HttpsIndicatorHeader True
This works great for the single pool. Below is the iRule for the VIP that calls multiple pools:
 switch -glob [string tolower [HTTP::uri]] {
   "/uriX/uriZ" -
   "/uriX/uriZ/" -
   "/"          { HTTP::respond 301 "Location" "https://www.websitename.com/uri/uri/uri" }
   "/abc.def*" { pool poolnameA_pool }
   "*/xyz/*"        { pool poolnameB_pool }
   default      { pool poolnameDefault_pool }
Could I do something as simple as this to make this work?
    if { [active_members /partition/poolnameA_pool] < 1 ) } or { [active_members /partition/poolnameB_pool] < 1 ) } or { [active_members /partition/poolnameDefault_pool] < 1 ) } {
        return
You’re going to three separate pools, which could each independently be down. Maybe something like this makes more sense?
        "/uriX/uriZ" -
        "/uriX/uriZ/" -
        "/abc.def*" {
            if { [active_membes poolnameA_pool] > 0 } {
                pool poolnameA_pool
                return
        "*/xyz/*" {
            if { [active_membes poolnameB_pool] > 0 } {
                pool poolnameB_pool
                return
        default {
            if { [active_membes poolnameDefault_pool] > 0 } {
                return
You definitely use the hash character to make comments.
"/abc.def*" {
         sending to pool poolnameA_pool
        pool poolnameA_pool
         poolnameA_pool not available
        return
