Hi All, We are using the BIG-IP LTM (10G) Virtual version 13, on Openstack One question, when F5 will use SR-IOV ability, how many transaction per second to make the F5 LTM use SR-IOV ability?
Thank you, Yoav
Thank you, Yoav
Thank you, My questions is how many transaction per second to make the F5 LTM use SR-IOV ability? Or when configure the SR-IOV it will always work with the SR-IOV?
Thank you!
When enabled with SR-IOV, it is on all the time.
Thank you!
One more important question, We are using BIG-IP LTM (10G) Virtual version 13, Where is can find the max L4 HTTP requests per second & Maximum L4 concurrent connections, with and without SR-IOV?
Please review the VE datasheet: https://www.f5.com/pdf/products/big-ip-virtual-editions-datasheet.pdf
Up to 135,000 L4 CPS or 625,000 L4 CPS with the High Performance VE license.
