Big-IP installation step by step guide
We want to install Big-IP F5 on On-prem kindly share some articles which will help to install F5 from start to end.
Hi  @ab7  ,
There are many manuals and guides to start your configuration for all modules, a good way to start is:
Hope its work.
This is not an easy task and should not be taken lightly.
You will not be able to properly configure a stable, ha pair by ONLY following a click - click - click guide, unless you have dozens probably hundreds of hours of administration under your belt.
If you are looking to fast track this, i would recommend you run as fast as  you can thru the certifcation prep work.   Techically - you would need to focus your learning on 301a.   I would strongly advise starting at the bottom and building your base 101 -201-301a-301b   before embarking on a quick solution that does not fit your needs. You dont need the certifcates to be able to do an install however, they do cover all the complexitys of doing it properly.
