BIG-IP 11.4.1 Build 608.0 Final VE
I’m in .NET 4.5 C : using proxy classes generated from WSDL, I call into iControl API to retrieve BIG-IP system configuration :
var systemConfigSync = new SystemConfigSync("bigip", "admin", "admin", 600000);
long offset = 0;
SystemConfigSyncFileTransferContext context = systemConfigSync.download_configuration("bigip", 131072, ref offset);
throws exception :
Exception caught in System::urn:iControl:System/ConfigSync::download_configuration()
Exception: Common::OperationFailed
primary_error_code : 16908289 (0x01020001)
secondary_error_code : 0
error_string : Error opening file for read operations
On v11.4.0 , this call successfully retrieved the system configuration ( bigip.conf ). However, on upgrading to 11.4.1 it began failing.
