F5 BIG-IP Virtual Edition v11.4.1 (Build 635.0) LTM on ESXi
What exactly is a configsync ip address ? Does sending a request to this ip cause a device-group config-sync to occur ?
The docs offer only a very basic explanation :
"Gets the configsync IP address "
The iControl documentation isn’t going to explain BIG-IP features that aren’t features of iControl itself.
The config sync address is the IP address your BIG-IP will use to send and receive config sync related messages. That’s a BIG-IP feature not specifically related to iControl,
