Hi all,
after booting the 12.1 partition out of a 13.1 test installation, my machine is bricked. Being connected via console, the device keeps asking for a Hard Drive Password which i don’t know. Looks to me like the drive is locked by the ATA password function. I can’t even perform a disk erase and/or clean installation like mentioned here, because the drive can not be accessed.
Any idea how I can get that thing back to work on my own, or do I need to send it in?
Thanks in advance!
I have opend a ticket now.
I’ve got it running again. Support says that
RMA process is rejected in those cases due to the issue was caused by an external factor
I have no idea in what way a reboot to another software using the GUI is a issue caused by external factor.
I solved my problem by guessing the password. So for all of you who run into the same problem, the ultra secure password with
the main goal [to] protect the hard drive, even, for internal administrator
is: f5
After that I was able to wipe the disk with the integrated disk-wipe utility (press “e” on startup) and perform a clean install from external DVD-Drive.
