Dears,
could you please have any idea about running a script to have an output about Big-IP health check (CPU status - memory - Fan - etc … )
your response is highly appreciated
Thanks,
Dears,
Thanks,
Hi Eslam,
The most complete option would be to run qkview from the CLI or GUI (under System | Support), upload the resulting tech.out file to https://ihealth.f5.com and check the report.
Aaron
Hi Aaron,
I checked that, there is a history tab in the dashboard view,
but i couldn’t export these history values
when i tried to export, it notified me that “u can save it as CSV file”, but without any output files located on my machine,
do u have any idea about this behavior, my current OS version in 10.2.3
Thanks for your feedback
You need to check the box(es) for which metrics you want to export. If you want to export everything, you can click the box next to history and all child checkboxes will be marked.
Aaron
i already did that Aaron, with no output files exported,
i don’t know if is it a bug or i have to enable something to be allowed to get the result
Sorry, I tested before I posted on 11.1 and a csv file is saved. The same test on 10.2.3 fails. I’d open a case with F5 Support to troubleshoot this.
Aaron
Thanks Aaron, i got it, it is a software bug
