Big IP F5 2000 model - Multiple VLANS
Hi Team,
We purchased an F5 model BIG-IP F5 2000 and currently I need some help from your team.
We got totally 8 Vlans in our network and I need to add all configure all those VLANs to my F5 for load balancing the applications servers in our network
when I check the F5 device, I could see only 4 external and 4 internal ports, so how can add all those VLANS.? is it possible to add only 4 VLAN?
Can any body Please provide me the detailed steps for this action item.
Thanks,
Akhilesh
can’t you use vlan tagging (802.1q)?
Can you please elaborate more on this?
Tag-based access to VLANs
Thanks.
so using VLAN tagging, for one external and internal port how many VLAN i can add? if this is the case why we need multiple Ethernet ports on Load balancer, cant be use one port for external and one port for internal? excuse me if I am wrong.
so using VLAN tagging, for one external and internal port how many VLAN i can add?i think it is equal to maximum number of configurable vlans.
sol3539: The maximum number of configurable VLANs
if this is the case why we need multiple Ethernet ports on Load balanceryou can bundle multiple interfaces (802.3ad) and use vlan tagging (802.1q).
cant be use one port for external and one port for internal?yes, you can use one interface for external vlan and another interface for internal vlan.
