BIG-IP Edge Client v1.0.6 for iOS 7
With all your other iOS 7 updates (if you’ve made the plunge), if you are running the BIG-IP Edge Client on your iPhone, iPod or iPad, you may have gotten an AppStore alert for an update.  If not, I just wanted to let you know that version 1.0.6 of the iOS Edge Client is available at the AppStore with iOS 7 support.
Customers who use UDID in their access policies should have users update to this version.
The BIG-IP Edge Client application from F5 Networks secures and accelerates mobile device access to enterprise networks and applications using SSL VPN and optimization technologies. Access is provided as part of an enterprise deployment of F5 BIG-IP Access Policy Manager, Edge Gateway, or FirePass SSL-VPN solutions.  BIG-IP Edge Client for iOS Features:
    • Provides accelerated mobile access when used with F5 BIG-IP Edge Gateway.
    • Automatically roams between networks to stay connected on the go.
    • Full Layer 3 network access to all your enterprise applications and files.
ps
Related:
Technorati Tags: f5,big-ip,edge client,ssl-vpn,mobile,smartphone,ios7,apple,iphone,ipad,silva,remote access,security,secure access,apm
Connect with Peter:Connect with F5:
It looks like the Edge Client v1.0.6 for iOS 7 is able to pass the UDID to the APM (in session.client.unique_id).
However my tests at a customer site today tend to indicate that the Edge Portal 1.0.3 is not able to provide the UDID.
All my attempts to get the UDID from an iOS7 device running the latest Edge Portal returned an empty string.
I might be wrong as I was in a bit of a rush but, can you confirm ?
Many thanks
