I recently formatted my laptop (re-installing Windows 8). Now the BIG-IP Edge Client will not auto launch. The profile is set to have the client do so. I have another laptop with Windows 7 that works fine. The auto launch was working on my laptop before the formatting. Where does the BIG-IP Edge Client set it self for auto launch?
thanks.
uninstalled and re-ran setup as admin and it was added to startup.
Hi pspecht, thank you for asking this question as I am also on the path of auto-launching/connect with BIGIP Edge Client.
Before you launch BIGIP edge client, can your users have Internet access?I was thinking on how to deny Internet access if user isn’t connected through edge client.
I am thinking of using host-file to only allow traffic to F5 APM device and when user gets connected, client laptop should receive the necessary DNS server settings and also to set “Force Tunneling” option to force all traffic through VPN.
