We are currently doing a migration from Exchange 2007 to Exchange 2010 and use Edge Gateway for passing the SSL traffic. We do not use Edge as an LTM device. I am having issues configuring active sync for exchange 2010. I read about the deployment guide but it talks more about LTM then Edge gateway. I used the iApp for deployment but it complains about some persistent cookie profile missing. I really need to resolve this issue because its hindering the migration process. Any one else experience this issue?
Hi Amit, first I recommend opening a case with F5 support so we can track these issues with the Exchange iApp and so we can have a look at your configuration. Second, can you tell us more about your deployment? Which version of the iApp are you using? Where does the Edge Gateway forward the ActiveSync traffic-is it going to another load balancer? What are the exact choices you’ve selected in the template that produce this error?
thanks
Michael
Amit,
Can you please download and try the latest iApp for Exchange as announced here:
Once within that iApp, please select “This BIG-IP Edge Gateway or APM will provide secure remote access to CAS” scenario and proceed from there. You should get the full configuration created.
I assume that you want to get just the Exchange 2010 working, as ActiveSync apps are different between 2007 and 2010 and must be served by their respective CAS version-specific CAS servers.
