BIG-IP Design Issues
I am pretty new in F5 world and I have 2 design related questions:
1. Is it possible to create 3 VLANs (with Web servers farms) on 3 different DMZs connected to a Firewall (ex: Cisco ASA) and have the LTM in a different DMZ connected to the same firewall through a 802.1Q VLAN tagged trunk?
2. I want to have 2 datacenters in Active-Active mode; can the Advanced Routing Module check the availability of my servers on one particular site and if they are down, send a routing advertisement to my router (ex: OSPF) to change the route to those particular servers to the second datacenter?
Thanks very much for your help.
Fouad
Hi Fouad -
1) Should be, if I understand the question correctly. If the network looks like this:
LTM
          DMZ0
        Firewall
    DMZ1   DMZ2  DMZ3
servers  servers  servers
then you can use static routing on the LTM to route traffic bound for each DMZ subnet via the firewall interface.
2) Yes
You’re very welcome.
/deb
