BIG IP Configuration for SAP EP
We have configured BIG-IP as the Load Balancer for SAP Netweaver Ep 7.0 . The BIG-IP version is 4x.We are facing some issues , currently there are three EP servers , the load balancing is happening but as soon we click on some application its SAY the SESSION HAS EXPIRED.
Kindly advice what is the problem
Pankaj
Hello,
If you disable all but one server in the pool, do you still encounter the error? If so, it looks like you don’t have persistence configured (or configured correctly).
Aaron
