tl;dr - How can I delete a PBA block allocated to a specific client unde the CGNAT module?
Hello guys! Hows everybody?
I’m working on a CGNAT PoC with a client. Currently we’re running v12.1.3 on a VE.
The LSN pool is configured as PBA with 512 ports in each block. Everything works fine.
Since it’s a PoC there are a lot of tests we do. And I tryed to find a way of clearing/deleting the current block allocated to a specific client.
lsndb list pba shows the current block assigned to the client as follows:
[root@bigip1:Active:Disconnected] config lsndb list pba
LSN port block allocations
Client Port block TTL
10.0.1.100 192.168.1.10:2048 - 2559 271
1 port block entry found.
When I try to delete this block so I can test one more time, I get an error:
[root@bigip1:Active:Disconnected] config lsndb del pba
Error: PBA entries cannot be deleted
Deleting the client’s connection with ‘delete sys connection cs-client-addr 10.0.1.100’ clears the connection table but not the NAT block.
Question: Is there a way of deleting this entry for the PBA block allocated to the client? If yes how? I looked everywhere I could think of… I know I can configure a timeout (and actually this is what I’m doing right now to speed things up) but when this thing goes live I’ll have to configure a longer timeout and this is not a real solution I think…
Many thanks! Rafael
